| Message |
: time of running the lines, making sure everything is setup correctly, mounting everything, getting in there, replacing the injectors, the controls inside the car, etc. etc...5hrs is pretty good. IF you know what you're doing, it can be installed in 5-6 hours. But, there are a lot of little things that people that haven't done it before can overlook, like putting white-out on the spray nozzle to let you know which way/angle the spray is squirting. You want the spray to go with the flow, not against it.
Later, Phuong
 Rice Land
